I have a 2014 ISX Peterbilt with a 485 hp engine.
The ISX the computer was removed and I have access to a 2007 ISX computer -
will that work ?
If not -
Can you please tell me what computer(s) will work ? Or would be comparable to my
2014 Peterbilt 485 engine
Thanks for your time and expertise
no, you will need either a
4358814
5317106
or most likely a 5290170
would the ECM off of an 07 ISX be ok for a core ?
iSC is a typo in subject matter 2007 ISX ecm
Looking for compatibility to ISX 2014
(02-28-2016 )DSTdriver Wrote: [ -> ]would the ECM off of an 07 ISX be ok for a core ?
no, they will not give you the core with a 871 ecm for a 2350 ecm
Thanks for the info
Any suggestions for finding a used ecm ?
(02-28-2016 )DSTdriver Wrote: [ -> ]Thanks for the info
Truck stop, late at night, wear black, bring tools...
Hey, I had to say it, as it was kind of hanging there...
But, there is an outfit up in Kentwood MI that deals in used Cummins stuff, lots of ECMs, and his prices are reasonable. I have bought parts from him in the past, so far he is the cheapest I have found. And he will dicker, they are good guys from my experience.
http://nadieselparts.com
Try spalding auto in spokane just Google it.
Also, you can try LKQ truck. They are nationwide. I had good luck either both.
LKQ HD CORE Lansing, IL. Had good experience with them, friendly customer service and not expensive
