09-28-2016,
You said this is an autoshift? If so turn your jakes on then turn them off and see if it is the same sound. If so then you may have the transmission turning them on to slow down.
(09-28-2016 )Signature620 Wrote: [ -> ]Do you have much experience with this engine? This is a fairly involved task to walk through over the internet. If you don't have the necessary tools and knowledge, you should take it to someone with does.
EDIT: Just saw the photo...That roller is only just starting to go. What does the cam look like? If the cam is severely damaged it could be the source of your noise, but judging by the roller I'd guess it is not yet bad enough to make much sound.
(09-28-2016 )rgreen Wrote: [ -> ](09-28-2016 )Signature620 Wrote: [ -> ]Do you have much experience with this engine? This is a fairly involved task to walk through over the internet. If you don't have the necessary tools and knowledge, you should take it to someone with does.
I think i might need to do a overhead set to see if that might take care of the problem the truck as over 927,000 plus miles. Actually number 1 roller and number 6 roller both have to same scarring starting take place
(09-28-2016 )Signature620 Wrote: [ -> ]I would most certainly do a valve adjustment, and make sure you drop your oil at recommended intervals. (Somebody can chime in with the correct miles, but in Aus it's 20,000km)
(09-29-2016 )rgreen Wrote: [ -> ]Does anyone know where I can get a service manual online ISX 435ST
(09-29-2016 )Hammerhead Wrote: [ -> ](09-29-2016 )rgreen Wrote: [ -> ]Does anyone know where I can get a service manual online ISX 435ST
Sign up for a Quickserve online account. Up to 5 engine S/N's for free, and you have a complete service manual with total tear down and reassemble procedures for the entire engine.
An invaluable resource
(09-29-2016 )rgreen Wrote: [ -> ]I have one more question can I use this beam torque wrench instead of dial
http://www.sears.com/craftsman-3-8-in-dr...ockType=G2
