02-29-2024,
Greeting to everyone!!!
I got a Cenworth truck with we’ve swapped engine 2350 and original ECU 2250 plus bad delete.
Truck was running okay for a couple years, let’s say but now statted to derate.
No other codes, only derate code. Data monitoring shows 00 reference voltage for turbo, actuator and exhaust pressure sensors but reference voltage is present at the harness connector.
So I’m sure the codes are blocked
I found similar problem in this forum, and I think Rawz said there is a way to build one software out of w to make it work write.
I would try to upload/download fresh factory, calibration file with your help, as I have most software I think
Please please help thanks, in advance!!!
