02-28-2016,
02-28-2016,
(02-28-2016 )Waterloo Wrote: [ -> ]That is my question! Can a radiator of such small size be recored? Or, just get a new one?
Yes they can but you need to find someone,you need a old school shop or a custom shop or some one that can tig aluminium.Most likely more expensive than a new rad.
02-29-2016,
(02-28-2016 )mkmac Wrote: [ -> ](02-28-2016 )Waterloo Wrote: [ -> ]That is my question! Can a radiator of such small size be recored? Or, just get a new one?
That's is what I kind of thought... Cost was my issue, nothing on these things is cheap, unless you want to wait or pay outrageous shipping costs.
02-29-2016,
You could just run the coolant to the engine and back. Mine was like that and I had no issues. Be sure to put valves on it he lines at the engine so if you get a leak you can close it off.
02-29-2016,
Try calling apu center in Stratford mo. I believe someone on here had some work done and was bragging on the price. They sell parts.
03-01-2016,
I went with these guys... http://www.thermobyproducts.com/default.asp
New radiator, made in the same Chinese plant that supplies Thermo King, $155.00 I also bought a new fan for $79, with my luck my old fan would fail a few days after installing the radiator...
Local TK dealer Radiator was $356, my favorite TK shop in Delphos OH was $256.
The fan was $350 at my local TK dealer, $250 at my Delphos shop... What a ripoff these parts are...
