| Replaced isx cm2350 actuator, low power/engine - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Replaced isx cm2350 actuator, low power/engine (/showthread.php?tid=10660) Pages: 1 2 |
RE: Replaced isx cm2350 actuator, low power/engine - Nerv - 07-13-2026 >recently replaced exhaust pressure sensor with new oem >i will check if it is dirty or not again but it has not been long since doing so, maybe few months. >the actual insite cummins code is Cummins fault code 1145 (SPN 656 / FMI 7) refers to: Injector Solenoid Driver Cylinder 6 - Mechanical System Not Responding or Out of Adjustment. >i will do the leak down test and report back >i cleared the codes, re did the install/calibration of the actuator and now am getting 30pounds of boost and engine brake is stronger, I will know later tomorrow whether or not it is back to normal power/engine brake, as we will be hitting the mountains with a 60k lbs load. (07-13-2026 )Rawze Wrote:(07-13-2026 )Nerv Wrote: Did the new ecm file update, just took it for a run this morning with a small load, now i have a fault 1145 spn 656 injector solenoid driver cylinder 6 - not responding or out of adjustment. I did clear all fault codes twice after flashing the new file. Not sure where to look now.. |
