Gear oil - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Gear oil (/showthread.php?tid=10167) |
Gear oil - Jchism3406 - 06-16-2025 Is it okay to use a gallon of Super tech gear lubricant 80w/90 gl5 in a Cummins isx cm570. I see a few people recommends the sta lube but we don’t have it. And Amazon wants $75 for a gallon. And also I’m sorry if this has been posted before. Don’t know how to use the search function here RE: Gear oil - hookliftpete - 06-16-2025 Yes, should be fine to use supertech, usually what I use RE: Gear oil - hhow55 - 06-17-2025 (06-16-2025 )Jchism3406 Wrote: Is it okay to use a gallon of Supertech worked for me when i had a 570. RE: Gear oil - Mrkentee - 06-18-2025 (06-16-2025 )Jchism3406 Wrote: Is it okay to use a gallon of That’s what I mostly use in my 871. I liked the Sta-Lube, and would order it online until they started making it out of gold bullion. I don’t know who pays those prices, but it’s not me. RE: Gear oil - SquareOne - 06-21-2025 (06-16-2025 )Jchism3406 Wrote: .... Don’t know how to use the search function here If you look just above the 'Gossip Box' on the left of the page, you will see a white box with the message "enhanced by G." Thats where the keywords will be entered for searches. Type in a keyword(s) (in this case for example, gear oil), press the blue box with the magnifying glass, and it will bring up, in a separate pop-up, any related threads/posts containing those keywords. Excellent tool to use as this forum has loads of info covering a lot of ground! |
