Rpm adjustment - Printable Version
+--- Thread: Rpm adjustment (/showthread.php?tid=10207)
Rpm adjustment - Scoot5869 - 07-08-2025
I was wondering if you can adjust the tachometer on a kw t880 it reads 150-200 degree higher than what insite says. Thanks
RE: Rpm adjustment - Btech - 07-09-2025
There is no adjustment for them, if its not reading correctly it has a issue with the needle motor/driver.
(well... I guess you could try the old move the needle... but I can't recommend... way to easy to really mess it up.)
RE: Rpm adjustment - Mrkentee - 07-10-2025
Just for fun you can get an rpm reader from Harbor Freight and see what it actually is. I used it for setting up my PTO. Not too much money, I don’t think.
https://www.harborfreight.com/digital-photo-sensor-tachometer-66632.html
RE: Rpm adjustment - Scoot5869 - 07-10-2025
It has two rpm gauge the digital readout and the old needle style. The digital one matches what insite says I just find it annoying that they don’t match lol. Thanks though
