Connecting rod - Printable Version
+--- Thread: Connecting rod (/showthread.php?tid=10209)
Connecting rod - Mcwrench94 - 07-10-2025
Was curious if any could answer what the difference is between pn 2882582 and 3689108 rods. I broke them down in QS and everything looks the same but according to QS they dont cross. I would like to use the 3689108 rods out of a cm2350 X114B in a cm2350 X101. Crankshaft and rod bearings are both the same.
RE: Connecting rod - Btech - 07-10-2025
3689108 is the latest supersession for 2882582.
Anymore you need to use parts.cummins.com and be logged in, (if your not logged in sometimes it won't show supercessions) to get the latest info as any parts info on quick serve is no longer updated.
RE: Connecting rod - Mcwrench94 - 07-10-2025
Awsome. Thanks for the help!
