| 2010 isx cummins needs demandating - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: 2010 isx cummins needs demandating (/showthread.php?tid=10326) |
2010 isx cummins needs demandating - Daniel0030 - 09-25-2025 Looking for de-mandating a 2011 t660 isx is 2010. had a someone, but doesn't answer anymore. please help RE: 2010 isx cummins deletes - Rawze - 09-25-2025 Assuming you live in a country where that stuffs is ok to do ... (doing it yourself)... - Just copy the program out of the ECM and email it to to me for a proper review / inspection ... and then things can be changed from there. Info on copying program out yourself: https://rawze.com/forums/showthread.php?tid=8425&pid=72945#pid72945 ... and if your looking for someone to just connect to your PC and charge you a bunch of $$$ to to everything for you while you close your eyes, then there are only a couple few people that are officially recommended as safe on here for that kind of thing. They are at the bottom of the post in the link. |
