Another typical (bad) CM870 delete ... - Printable Version
+--- Thread: Another typical (bad) CM870 delete ... (/showthread.php?tid=10446)
Another typical (bad) CM870 delete ... - Rawze - 12-29-2025
Just what the title says. Another typical (bad) CM870 delete. Actually, 2 files were sent to me, one supposedly de-mandate but leaves the 565hp-1850trq alone, and the other one with some 'tweaks' that was supposed to be same but has power (supposedly) changed to 600hp-2050trq.
It is a bad delete for sure. Welcome to the bad delete club. BOTH programs are engine killers.
The vehicle owner says something about the engine fan coming on all the time with the 'added power' program. No wonder, its garbage-can tuning at its best.
The vehicle owner unfortunately however claimed that the 565 file 'seemed to run good '.. but this is exactly WHY people convince themselves that their de-mandate program must be the rarest program of the year, and is somehow ok. This is as far from reality as it gets. - Here is why...
The vehicle owner also claims that 'this tuning guy', who shoved these horrible, corrupt programs into his ecm, is claiming that all his issues are with the engine / mechanical. - How convenient, eh?...
- My suggestion.. let your 'tuning guy' see this post and let them know that what they are doing needs some serious improvements! so that they stop causing damage to every red engine they touch.
Also to get this crap out of that engine and have it re-done properly.
Here is what was seen in the file when reviewing these programs ...
engine ser# 79213175: calls for program = AB10352.xx from factory ...
First Program: (non added power) ... The one that is claimed to 'run ok' ...
== The Air inlet temp logic for high and extreme altitude conditions (4,000 feet and up) has been edited and essentially destroyed.
NOTE: These setting(s) do NOT need to be edited for a de-mandate, or for power changes to happen.
== engine operating mode control logic re-mapping is incomplete/incorrect. The ECM will NOT remain in its non-egr engine mode, causing ghost issues and progressive engine damage over time.
== The fuel-air-mix settings for low altitude and non-egr engine modes has NOT been edited at all. This causes the engine to run too lean and become harmful to itself.
== The fuel-air-mix settings for high and extreme altitude conditions (4,000 feet and up) has been edited incorrectly and essentially destroyed. - Did someone mistake these for the tables that they were supposed to actually edit?. Did someone use third garbage software like W*ols/Efi trash that is notorious for corrupting engine files and editing the wrong settings?.- Who knows for sure.
== The injection timing tables were edited, and at low altitude and no-egr modes, they are not harmful, but for higher altitude modes, they are too far retarded, becoming problematic.
NOTE: It looks like someone just dumped the same exact table into all modes with no regard to their needs.
== The turbo RPM upper boundary is set to NOT allow over-spool errors, allowing it to destroy itself without any alarms.
== Surge and other over-spool and power-boost protection logic has been damaged or disabled.
== Intake air flow estimation logic/estimation has been removed/damaged.
== Some logic settings that are supposed to only be set to a '1' or a '0' are set to erroneous values. This is evidence of file corruption either by programming mistakes, or by third party software corruption?.
== Aux. emissions settings are incomplete or have been missed. This will make the boost levels unstable under hard acceleration and/or high power requests.
== The axis/reference headers on fuel-mix, injection timing and other tables has been heavily damaged. This is evidence of file corruption either by programming mistakes, or by third party software corruption?.
== Fuel-flow settings for LP-Gas (optional westport lp gas injection system), which are completely disabled on this engine, have been damaged or destroyed.
NOTE: This is a clear sign that someone does not know what these settings are for... or is a result of file corruption.
== Some EGR settings were done incorrectly (set the wrong direction). this can create ghost issues.
Second Program: (added power) ...
== this program has ALL the issues of the first program, however, it is set more harmful...
== Injection timing has been set to EXTREMELY HARMFUL LEVELS for the engine. This will significantly shorten engine life, leading to head gasket failures at higher power levels.
== The timing actuator delay has been set to harmful position(s) at higher power levels. This will significantly shorten engine life, leading to head gasket failures at higher power levels.
== Fuel quantity data has been heavily damaged in attempts to dump fuel in' against the ecm's will. This will trigger engine overload logic and cause the engine to fight directly against this ghost power being produces that it is not commanding.
NOTE: This may very well be why the engine fan comes on in a ghost fashion, as the ecm will fight tooth and nail to bring the power back down that has been added against its will. The engine fan activation (to help force a reduction in engine power output) for engine overload conditions has not been switched off. This is likely the trigger for the ghost engine fan issues that 'seems to come and go' at will, or happen during hard acceleration. The ecm is trying to protect itself from the {garbage-settings} unknown quantities of fuel being dumped in against its will.
== The power curve is set to have the engine try to make more than 800+HP,.. and NOT the 600/2050 that it was set to advertise itself as. - this is a lie and is also EXTREMELY HARMFUL!.
RE: Another typical (bad) CM870 delete ... - OhKarma - 12-30-2025
(12-29-2025 )Rawze Wrote:  - My suggestion.. let your 'tuning guy' see this post and let them know that what they are doing needs some serious improvements! so that they stop causing damage to every red engine they touch.
Out of curiosity, how often do these tuner get in contact with you to see their mistakes and make an effort to correct them? Can’t even imagine how many just keep going on to tune for others and put the blame on anything but their tune
RE: Another typical (bad) CM870 delete ... - Rawze - 12-31-2025
- It does not happen. People who do bad programming always curse me out and make a big stink in an arrogant stance that 'they can do no wrong' because 'no one else complains'.. while they tear up more engines on a daily basis. Its an absolute plague.
Its like the 30+ year veteran mechanic that works in the shop... tightening cylinder head bolts with a pair of rusty, worn out pliers, destroying everything they touch, chewing up heads bolts, etc.. ... and when you walk in and politely offer to hand them a proper torque wrench, socket, etc. (for free nonetheless),.. its the same thing.
Replies are always nothing but hostility, anger, and sheer narcissism. This is what you get in return for even daring to ask them something nonetheless point out serious mistakes. All you achieve by trying to be helpful is a bunch of excuses and chest pumping claims of 'They have been doing it this way for XX years' .. so 'Who the f%k are you for questioning' their superiority ... and that you, not them, are the one who is the problem for even considering that they might not know how to set or do something properly.
RE: Another typical (bad) CM870 delete ... - mikkhh - 12-31-2025
99% of those "tuning gurus" have never even taken apart an engine or put it together.
Some guys who "do programming" flat out say that they do not fix any mechanical issues on engine, they are afraid to get hands dirty and even more afraid to admit that they are wrong.
Some keep blaming that aluminium inline6 diesel engine blocks are the culprit for cracking between 2nd and 3rd cylinders after their stage 3 or whatever of engine desctruction modifications.
Older European car engines were still based heavily on oldschool mechanical diesel injection hardware so there was still huge margin of safety compared to newer stuff that is designed from scratch for efficeincy and emissions. Also lots of euro manufacturers were cheating with emissions especially around 2005-2015 era and they used way less e g r than they should have used, that with along oldschool design also helped to keep engines together for "tuning gurus". Why those tuners did not report or knew about emissions cheating done on modern cars? To this day engine modes are a new concept to most of them.
Then something changed and car engines got developed from scratch to meet latest euro5 emissions were starting to use e g r under full load, but that thing started to happen mostly on 2010+ engines and 2015+ started to use both low and high pressure egr.
Those first engines that were made from scratch to use full load e g r and did not cheat with emissions were the ones that got plagued for poor reliability and longlife service intervals (30 000 miles for oil change on vans, 20 000 miles on cars) also took a toll on engines due to increased soot load in oil. How this is relevant to red engines? Well hook up a scan tool to any 2015+ car or truck and see live data what engine mode it is running, there are lots of operating modes, most makes have them at just some cryptic numbers, but by quessing using self study programmes or introductions of new engines they mention periodic regenerations of catalytic converters and those things fully correspond to engine mode operating changes while driving. Also dpf regenerations have different operating mode, when you fully floor engine then also mode changes, you can also look at fuel rail pressure to get a quess what combustion logic the engine is running. but some fuel systems have hydraulic amplification so the rail pressure and injector tip pressure may not be 1/1.
Keep in mind that most those "tuning gurus" started from cars and moved over to trucks. There is big difference running wise, since cars are not usually fully loaded and load on engines is quite small compared to commercial equipment. How any of them tell that it is MUST DO to clean intake etc before doing any tuning or deman? How any of them check for faulty sensors?
RE: Another typical (bad) CM870 delete ... - stevesparts - 12-31-2025
This sound's like the guy who use to/still? ran around in colo. and trash engines, saying he was the best thing and just trashed a lot of trucks around here. He tuned a truck here in town. and tried to talk me into letting him do my truck. I said F#$! no he got all mad . well 2.5 weeks late the poor kids engine was dead BIG hole in the side. same sad story.
