Lower air leaf hanger broken bolt - Printable Version
+--- Thread: Lower air leaf hanger broken bolt (/showthread.php?tid=10510)
Lower air leaf hanger broken bolt - Redland1 - 02-13-2026
Found a broken bolt on my lower air leaf hanger. Why do they break ? And also how hard is it to fix ?
RE: Lower air leaf hanger broken bolt - Rawze - 02-14-2026
maybe a couple pics?.
RE: Lower air leaf hanger broken bolt - Redland1 - 02-14-2026
(02-14-2026 )Rawze Wrote:  maybe a couple pics?.
It was a Michigan truck up until 4 years ago.
Picture of the broken bolt
RE: Lower air leaf hanger broken bolt - marek4792 - 02-14-2026
Almost looks like water and road treatment intrusion plus the rust jacking. Better nip it in the butt before the frame rails are too far gone..
RE: Lower air leaf hanger broken bolt - Mrkentee - 02-15-2026
I was sitting loaded in my 2010 PB and heard a pop. A big nut and bolt that holds the bracket for the step just snapped like that from corrosion, I guess. Had me worried the truck was falling apart. It’s only happened that one time. I had the bracket off before, so maybe I over tightened it, but I doubt it.
But a huck bolt breaking. Not what you want to see.
RE: Lower air leaf hanger broken bolt - Rawze - 02-15-2026
I think I would be smacking all the huck bolts with a 5-lb hammer to see if there are any more.
