| 2019 international lt625 def delete - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: 2019 international lt625 def delete (/showthread.php?tid=10622) |
2019 international lt625 def delete - Rare22 - Today After purchasing a deleted truck it ran perfect when it was bobtail but once I put a load on it. It had a code pop up SCR 25% derate. I asked the seller who go me in contact with the tuner and said it fine likely due to low coolant or anything else so it will show that code. I did indeed have low coolant once I topped it up (it was leaking from a loose clamp) the code never went away. And the mpg are horrible. While loaded with 8k lbs I get 5.5mpg!!!! I see that the truck has great power from 1-10 speed but at 11th and 12th gear since it’s an automatic the truck is very sluggish! I noticed it had a boost leak and I’m chasing them down when I fix a boost leak I would get good mpg for 30mins then it would go back down. Do you guys think I have more boost leaks to chase down or possible a bad tune? Thank you! RE: 2019 international lt625 def delete - mikkhh - Today bad tune. First step pull the programming and have it looked over. https://rawze.com/forums/showthread.php?tid=8425&pid=72945 First things first you need a genuine nex iq adapter or cheap chinky in line 6 adapter. RE: 2019 international lt625 def delete - Rawze - Today (Today )Rare22 Wrote: After purchasing a deleted truck ... Like mikk said.. copy program from ecm and e-mail it to me for a proper review of what someone did in there. ... also, I would not have purchased a 'deleted' truck unless the person was giving it away almost for free + you had enough moneys to spare on it to properly inframe the engine right away. MOST delete programming is absolutely harmful to the engine internals.. and this is before some idiot even turns up the power. You also need to take a hard look at what mechanical changes were made ... == Does it still have the VGT turbo on it?. .. if not then that is your next move.. to re-install the VGT onto it. == Does it have blocking plate between manifold and front of egr cooler?. - Does it have one at the intake where the egr pipe comes across? ... Does it even have the EGR cooler still on it or at least a bypass pipe to allow proper coolant flow to the back of the block??. == Are all 3 cans fully hollow all the way to the bare metal (DOC/DPF/SCR)?... or just some half-arsse holes drilled thru the elements and now are reflecting a lot of heat back at the engine/turbo?. == what is the boost getting to in a hard pull?. - Does it even have a boost gauge on it? .. so on and so fourth. |
