| C*TERM - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: C*TERM (/showthread.php?tid=10650) |
C*TERM - Lordsoldier1 - 06-26-2026 Is there anyone that can help me create screen files for demandating, horsepower tuning all of that? Or at least a first step into learning ecm modifying. RE: C*TERM - Rawze - 06-26-2026 (06-26-2026 )Lordsoldier1 Wrote: Is there anyone that can help me create screen files for demandating, horsepower tuning all of that? Or at least a first step into learning ecm modifying. The proper place to discuss engine/ecu programming, tuning, using Calterm, etc. is over on my mumble server. If someone is serious about getting involved in detailed discussions on these subjects, then that is the place to be. This also includes free professional level training/help ... == How Enigne control modules work and their typical logic structure. == Overall system circuit and management structure with regard to programing. == Discussions about engine tuning software, including CT and others. == CLasses on EGR, boost, Compression ratio, Injection timing, and all other relevent topics with concern to ecm programming. == Assisitance writing your own programming so that it does not shorten engine life. ... and much more. ================== The mumble software itself is free, and it costs nothing to participate. == On the PC, the program is called 'Mumble'. On the smart-phone it is often called 'Mumla', or 'Plumble', or 'Mumble', it depends on the brand of phone. The server is private and unlisted, so it has to be added manually when you join for the first time. == The private server address is ' mumble.rawze.com '. Here is a link to the mumble software for the PC: https://www.mumble.info/ Here is some additional info for setting up mumble / getting onto our private server specifically: http://rawze.com/forums/showthread.php?tid=53&pid=2163#pid2163 |
