egr cooler blockoff - Printable Version
+--- Thread: egr cooler blockoff (/showthread.php?tid=10665)
egr cooler blockoff - sslack - 07-13-2026
I have a x15 that has been demandated. I am installing a new turbo and a non-egr manifold on it and looking for a complete block off kit to do away with the cooler, if such an animal exists.
Does anyone out there know of any? If so, I would greatly appreciate the info.
RE: egr cooler blockoff - Rawze - 07-13-2026
(07-13-2026 )sslack Wrote:  I have a x15 that has been demandated. I am installing a new turbo and a non-egr manifold on it and looking for a complete block off kit to do away with the cooler, if such an animal exists.
I would not suggest it, as it makes for red flags if anyone opens the hood.
next to that, The coolant flow from the water pump to the back of the block (passing thru the egr cooler) cannot be disabled. A 3/4" hose needs to be put in its place. Best thing is to simply keep the cooler in place because of this ... or a kit that allows for the coolant flow.
