| SOI Advice - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: SOI Advice (/showthread.php?tid=1385) |
SOI Advice - Signature620 - 01-24-2017 Hi all, I'm looking for opinions on SOI increments for an Aussie CM871 E after @m*m^2. I currently have a few on the road set at 4 degrees. A couple of these trucks do a lot of high torque/load work so I just want to know if I should go a little closer to 0 since 4.5 is the recommended max for the bigger injectors. Cheers. RE: SOI Advice - AussieISX - 01-24-2017 I wouldn't run any more than 8 degrees in the 395mg/Str areas . Won't gain enough fuel economy to justify cracked Pistons . RE: SOI Advice - Signature620 - 01-24-2017 Is that 8 degrees in total or as an increment? RE: SOI Advice - Rawze - 01-24-2017 Setting one to 4 or 4.5 (8 for smaller tier engines) is all about fuel mileage, and not for higher torque applications. It is ok to set one out that far only if you only use higher torque on occasion, and your average engine loads are 30% or less (typical of a highway truck in usa.). for higher torque applications though,.. this is a bit risky. I would not recommend more than about 2 or 3 in constant high torque applications on one. I have even heard of a few guys set it to -0.7 for road trains for optimizing the 1650 RPM range. RE: SOI Advice - AussieISX - 01-24-2017 (01-24-2017 )Signature620 Wrote: Is that 8 degrees in total or as an increment? 8 degrees total RE: SOI Advice - Unilevers - 01-24-2017 typically most trucks under heavy load run 1-3.5 in the SOI tables. A max (and slightly risky) would be 8 degrees BTDC total which would give you 4.5 on the increment to be there. Personally i would run the increment down to 2-3 to give you more of a safe margin and a total BTDC of 5ish. if you are unsure of the driver and loads run a 0 increment to be on the safe side. a running engine is better than i blowed up efficient one. my 0.02c RE: SOI Advice - kmk - 01-24-2017 I always thought that the cm871 has knock limiting tables that take precedence over user soi increment and torque demand? Can you guys go into further detail. Thanks. RE: SOI Advice - AussieISX - 01-24-2017 (01-24-2017 )Unilevers Wrote: typically most trucks under heavy load run 1-3.5 in the SOI tables. A max (and slightly risky) would be 8 degrees BTDC total which would give you 4.5 on the increment to be there. Personally i would run the increment down to 2-3 to give you more of a safe margin and a total BTDC of 5ish. There is nothing slightly risky about running 8 degrees total in either 3774 or 2965 Cpl cals , As the stock cal peaks at 7.5 degrees @1650-1750 Rpm in the alpha 1 tables . That is why I said 8 degrees total advance . If he added the 2-3 degrees you advised he would have ended up with a total of 10.5 degrees. Just putting an incremental increase on these tables is bad in my opinion and they should be edited correctly . I think before giving advice you need to be familiar with the cal in question. I have trucks running in the north of Australia pulling 167,000 kg ( 368000lbs) on 24hr operations using the same timing I suggested. Those trucks are not owner driven and have been running this tune for nearly 2.5 years without any cracked Pistons or any problems outside of normal issues. RE: SOI Advice - Signature620 - 01-25-2017 I tried one at 2 degrees today and it ran about 150 deg celsius hotter on the pyro and the coolant temp rose quicker than normal. Where can I read up on adjusting the SOI tables for a 2965/3774? |
