| cm 871 incal updated AV's - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: cm 871 incal updated AV's (/showthread.php?tid=530) |
cm 871 incal updated AV's - NewSon - 06-17-2016 hi alll! does anyone have a list of the most recent updated cals for the cm871 , like a pdf. i know cummins updated AV numbers when they did some upgrades on emissions and stuff, so i need to know if , say AV10075 is updated to AV10256 ( random numbers). Thanks! RE: cm 871 incal updated AV's - ynot - 06-17-2016 I'm not looking at the cals but yes the higher number AV10200+ are usually for the updated dpf with the new CPL numbers like 3748, 3749 2732 = 3748 2733 = 3749 2734 = 3750 ( just guessing on this one been awhile since I've looked at them) the old cals and the new cals are very very close to the same just some differences in some of the emissions parameters, so if you've got the mandate fixed it don't matter which one you use. RE: cm 871 incal updated AV's - NewSon - 06-18-2016 understood. but I need to figure out if the engine has been fooled around with a completely different cal , or it is actually a correct, updated cal that belongs to that particular engine. i saw a pdf doc once on the web, but i was stupid enough not to copy it for me. now, i have a struggle finding it. it said something like: old cal AV10045 cpl 3245 updated cal AV10234 cpl 3246(example) RE: cm 871 incal updated AV's - Mr Hagg - 06-18-2016 I think this may help. I tried to load the whole thing but couldnt figure it out. Old Engine CPL ECM Calibration to be Used with DPF Part Number 4969701, 4969702, or 4969703 (See Table 2) ECM Calibration to be Used with DPF Part Number 5283669, 5283778, 5283799, 5297522 , 5297989, or 5297990 (See Table 2) New Engine CPL 1434 AV10002 AV10191 3746 1434 AV10003 AV10192 3746 1434 AV10004 AV10193 3746 1434 AV10005 AV10194 3746 1434 AV10006 AV10195 3746 1434 AV10008 AV10196 3746 1434 AV10009 AV10197 3746 1434 AV10010 AV10198 3746 1434 AV10011 AV10199 3746 1434 AV10012 AV10200 3746 1434 AV10014 AV10201 3746 1437 AV10020 AV10202 3745 1437 AV10021 AV10203 3745 1437 AV10022 AV10204 3745 1437 AV10023 AV10205 3745 1437 AV10024 AV10206 3745 1437 AV10025 AV10207 3745 1437 AV10027 AV10208 3745 1437 AV10029 AV10209 3745 1437 AV10030 AV10210 3745 1437 AV10032 AV10211 3745 1437 AV10034 AV10212 3745 4/19/2016 New Aftertreatment Diesel Particulate Filter Part Numbers for ISX CM871 and ISX CM871 Export Engines https://quickserve.cummins.com/qs3/pubsys2/xml/en/tsb/2010/tsb101096.html?q=5297522 5/9 1437 AV10034 AV10212 3745 1437 AV10036 AV10213 3745 2732 AV10055 AV10214 3748 2732 AV10056 AV10215 3748 2732 AV10057 AV10216 3748 2732 AV10058 AV10217 3748 2732 AV10059 AV10218 3748 2732 AV10060 AV10219 3748 2732 AV10061 AV10220 3748 2732 AV10062 AV10221 3748 2732 AV10063 AV10222 3748 2732 AV10064 AV10223 3748 2732 AV10065 AV10224 3748 2732 AV10066 AV10225 3748 2732 AV10067 AV10226 3748 2732 AV10068 AV10227 3748 2732 AV10069 AV10228 3748 2732 AV10070 AV10229 3748 2732 AV10071 AV10230 3748 2732 AV10137 AV10231 3748 2732 AV10138 AV10232 3748 2732 AV10149 AV10233 3748 2732 AV10181 AV10234 3748 2732 AV10182 AV10235 3748 2732 AV10183 AV10236 3748 2732 AV10311 AV10312 3748 2732 AV10313 AV10314 3748 2732 AV10315 AV10317 3748 2732 AV10316 AV10318 3748 2733 AV10044 AV10237 3749 2733 AV10045 AV10238 3749 2733 AV10046 AV10239 3749 2733 AV10047 AV10240 3749 2733 AV10048 AV10241 3749 2733 AV10049 AV10291 3749 4/19/2016 New Aftertreatment Diesel Particulate Filter Part Numbers for ISX CM871 and ISX CM871 Export Engines https://quickserve.cummins.com/qs3/pubsys2/xml/en/tsb/2010/tsb101096.html?q=5297522 6/9 2733 AV10049 AV10291 3749 2733 AV10050 AV10242 3749 2733 AV10051 AV10243 3749 2733 AV10052 AV10244 3749 2733 AV10053 AV10245 3749 2733 AV10054 AV10246 3749 2733 AV10139 AV10247 3749 2733 AV10165 AV10248 3749 2733 AV10166 AV10249 3749 2733 AV10167 AV10250 3749 2733 AV10168 AV10251 3749 2733 AV10169 AV10252 3749 2733 AV10170 AV10253 3749 2733 AV10171 AV10254 3749 2733 AV10172 AV10255 3749 2733 AV10173 AV10256 3749 2733 AV10174 AV10257 3749 2733 AV10175 AV10258 3749 2733 AV10176 AV10259 3749 2733 AV10177 AV10260 3749 2733 AV10178 AV10261 3749 2733 AV10179 AV10262 3749 2733 AV10180 AV10263 3749 2733 AV10307 AV10309 3749 2733 AV10308 AV10310 3749 RE: cm 871 incal updated AV's - NewSon - 06-18-2016 ohhh thanks a lot Mr. Hagg! thats what I am looking for! Thanks guys! RE: cm 871 incal updated AV's - NewSon - 06-18-2016 https://quickserve.cummins.com/qs3/pubsys2/xml/en/tsb/2010/tsb101096.html?q=5297522 if you log into quickserve, this link basicly says it all! hope it helps someone else , not only me! RE: cm 871 incal updated AV's - mitchtazz - 06-19-2016 I shi#t you not, I had a new DPF along with a load of other stuff done to my truck less then a month ago. And now I have a "faceplug" alarm active. Since I cant get the cummins diag software to work anymore I had to pull the codes using the "go peddle 3x" method. I just happened to stumble across this thread and checkEd my invoice and sure enough, my core was part# 4965129D, and the new filter is 5297522NX. Since I have to go to Rush for thermostats and to reset the alarms so my truck can start regen again, I'll have them check the call too. Hopefully I can get them to send the bill to Kenworth. |
