870 flywheel housing |
08-09-2019, (Subject: 870 flywheel housing ) Post: #10 | |||
RE: 870 flywheel housing This is on a log truck, it gets worked pretty hard. Do you happen to have any pictures of your cracked housing? | |||
08-10-2019, (Subject: 870 flywheel housing ) Post: #11 | |||
RE: 870 flywheel housing (08-09-2019 )tree98 Wrote: This is on a log truck, it gets worked pretty hard. Do you happen to have any pictures of your cracked housing? Gonna have to go looking. I thought I posted them in my thread User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
08-10-2019, (Subject: 870 flywheel housing ) Post: #12 | |||
RE: 870 flywheel housing | |||
08-11-2019, (Subject: 870 flywheel housing ) Post: #13 | |||
RE: 870 flywheel housing (08-10-2019 )tree98 Wrote: I didn't see any I threw the cracked housing away when I moved in the spring, so this is all I have for pics... This was clearly a crack, but I couldn't find a penetration to the oil rifle. There was obviously a leak directly from the oil rifle cavity somewhere, but I could pinpoint it. The leak increased dramatically from a sweat to a leak when I shimmed my oil pump, so it was rather conclusive that was where it had to be coming from. I inspected the gasket, the housing, and the block and could not find a stain showing where the gasket was leaking. Starlight stopped by my shop when I was just finishing up, and he agreed that it didn't appear that my gasket had failed, so I'm fairly certain it leaked via the cracks. Not all of these ^ are cracks, but it shows the poor quality of this particular casting IMHO. This was a distinct crack. It was visible both front and back, straight horizontal from the bolt hole going right. User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
08-11-2019, (Subject: 870 flywheel housing ) Post: #14 | |||
RE: 870 flywheel housing Wow, I hope I don't run into this. Mine isn't leaking yet so maybe there is hope. | |||
08-11-2019, (Subject: 870 flywheel housing ) Post: #15 | |||
RE: 870 flywheel housing (08-11-2019 )tree98 Wrote: Wow, I hope I don't run into this. Mine isn't leaking yet so maybe there is hope. I'm sure you're fine. I'm quite certain I know exactly when this happened:dodgy: There's an over beer story about it...you're in PA right? User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
08-12-2019, (Subject: 870 flywheel housing ) Post: #16 | |||
RE: 870 flywheel housing (08-11-2019 )Hammerhead Wrote: ... I wonder when your going to come this way for a week or so?. You have been saying it for years now. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
08-12-2019, (Subject: 870 flywheel housing ) Post: #17 | |||
RE: 870 flywheel housing yes hammer, when you going to go see rawze? | |||
08-12-2019, (Subject: 870 flywheel housing ) Post: #18 | |||
RE: 870 flywheel housing Yeah , hammer User's Signature: The missing link | |||
