KW900L |
05-28-2016, (Subject: KW900L ) Post: #10 | |||
RE: KW900L The one I have is a H00500C they are about 100.00 my factory one was a Hadley this one has better response. Does your truck have dual leveling valves. Some of them had two leveling valves? | |||
05-29-2016, (Subject: KW900L ) Post: #11 | |||
RE: KW900L (05-28-2016 )Bigcam3cummins Wrote: The one I have is a H00500C they are about 100.00 my factory one was a Hadley this one has better response. Does your truck have dual leveling valves. Some of them had two leveling valves? I think my leveling valve is a NEWA. I couldn't see any other names on it or a part number. My set up is a single leveling valve. ![]() I think I'll take a ride over to the parts counter and see if I can run down a Hadley. There is no telling how old my valve is and I probably should go ahead and get one and put it on. | |||
05-29-2016, (Subject: KW900L ) Post: #12 | |||
RE: KW900L The one I have comes with some brackets. But you might have to make something up to make it work. | |||
05-29-2016, (Subject: KW900L ) Post: #13 | |||
RE: KW900L I see "NEWAY"........ User's Signature: You want how much? | |||
05-30-2016, (Subject: KW900L ) Post: #14 | |||
RE: KW900L I have Hadley leveling valves in the front of my prostar ... I hate them!. the guts are cheap plastic and if I don't grease the guts regularly, they just break all the damn time!. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
05-30-2016, (Subject: KW900L ) Post: #15 | |||
RE: KW900L (05-30-2016 )Rawze Wrote: I have Hadley leveling valves in the front of my prostar ... I hate them!. the guts are cheap plastic and if I don't grease the guts regularly, they just break all the damn time!. Thanks for the info, I'll make sure I ask about the valves and internal parts when going to the parts counter. | |||
05-31-2016, (Subject: KW900L ) Post: #16 | |||
RE: KW900L So what would be a good replacement valve for him to use if the Hadley valve breaks all the time... I'm sure people have had bad experiences with all kind of leveling valve they are a moving part and they do take a shi#t kicking back there. Have you tried and different manufacturers valves on you prostar? | |||
06-01-2016, (Subject: KW900L ) Post: #17 | |||
RE: KW900L (05-31-2016 )Bigcam3cummins Wrote: So what would be a good replacement valve for him to use if the Hadley valve breaks all the time... I'm sure people have had bad experiences with all kind of leveling valve they are a moving part and they do take a shi#t kicking back there. Have you tried and different manufacturers valves on you prostar? I have not tried a different brand, Nothing else fits it. They last a long time if you limit air movement through them (less internal stress), and keep the plastic guts greased. I have needle valves on my air bags to limit air flow into-and out of them. That helps the most I think. It is less shock to the guts in the valves on bumpy roads. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
