Installing fuel pump cm2250
10-23-2017, (Subject: Installing fuel pump cm2250 )
Post: #28
RE: Installing fuel pump cm2250
(10-23-2017 )JMBT Wrote:  That is a 2 cylinder. The gear pump on the back of the 3 cylinder has the input and output holes on the bottom. The 2 cylider’s gear pump has the in/out on the top like the one in the picture.
However, it may be an early 2cylinder that still had ceramic plungers, so plan on a rebuild kit for the head whenever you get it anyway.
Thanks for this answer. It cleared a lot things up. He said it came out of a kenworth cummins isx 2350. From what I've read that they updated the plungers on 2350 engines. I have the 2250.
Post: #29
Pics that he Sent me
./uploads/201710/post_2913_1508815622_3f92c432e565b69c7a6fd648bd8e9f65.jpeg
Post: #30
More pics
./uploads/201710/post_2913_1508815671_4641b52aa5b258dc6b8a9003f8fcea9c.jpeg
Post: #31
Removed the head
./uploads/201710/post_2913_1508815898_0a5b62cd61c0418b71b1131ab6ef7d1c.jpeg
10-24-2017, (Subject: Installing fuel pump cm2250 )
Post: #32
Is fuel pump part# match with fuel pump part number for 2250? Check on cummins quick serve for pump gear compatibility.
 Thanks given by: 1776trucking
