Factory cal file help
03-27-2025, (Subject: Factory cal file help )
Hello. Im having problems with quickserve at the moment. Curious if someone can tell me what file this 2015ISX should have in it. Its a 450 engine someone has I'm sure put a 550 file in it.
Engine Ser-7984237
Cpl-4583
Currently has ECM code-EF10106.26, PN-5317106, SN-4198682, CPL-4585
Thank you for any help!
RE: Factory cal file help
(03-27-2025 )68shifter Wrote:  Hello. Im having problems with quickserve at the moment. Curious if someone can tell me what file this 2015ISX should have in it. Its a 450 engine someone has I'm sure put a 550 file in it.
Engine Ser-7984237
Cpl-4583
your engne ser# is missing a digit.
79874237
Sorry, fat fingered. Thank you.
(03-27-2025 )68shifter Wrote:  79874237
If you go to 'parts.cummins.com' and put in the ser# then it shows that it takes program EF10090. No login needed.
Thank you! Didn’t know that route.
