bad de-mandated programming
06-27-2025, (Subject: bad de-mandated programming )
Hello I recently started having issues with my mandated truck. Filters were full truck would go into regen every two to three hours and my local shop suggested it would be easier and more cost effective to just de-mandate it. I joined the forum because it seems like everyone who’s gone this route has had issues including myself. First trip after work was finished tubo started surging kind of like pulsing sound at idle I hooked up Cummins insite and I see turbo actuator command jumping to 90,80,70,50 percent it’s all over the place. As I’m driving 65mph on cruise control turbo actuator is comanded to 90 percent and truck bogs down really bad blows smoke out the tailpipe. I’m lost, local shops wants to replace vgt and I said no. I need help.
The work they did was hollow and emptied filters and I saw several sensors unplugged egr was not blocked off. Then I guess ecm programmed and That’s all. I’m not sure what’s missing what’s right and what’s wrong. I need help. Thank you.
RE: bad de-mandated programming
(06-27-2025 )SaulV95 Wrote:  Hello I recently started having issues with my mandated truck. Filters were full truck would go into regen every two to three hours and my local shop suggested it would be easier and more cost effective to just de-mandate it. I joined the forum because it seems like everyone who’s gone this route has had issues including myself. First trip after work was finished tubo started surging kind of like pulsing sound at idle I hooked up Cummins insite and I see turbo actuator command jumping to 90,80,70,50 percent it’s all over the place. As I’m driving 65mph on cruise control turbo actuator is comanded to 90 percent and truck bogs down really bad blows smoke out the tailpipe. I’m lost, local shops wants to replace vgt and I said no. I need help.
Like you already stated... Assume that the programming is not right. I review more then 1,000+ programs a year for people and more than 90% of them are complete garbage plus harmful to the engine.
And the turbo trying to make boost at idle, and those high positions is a bad sign. Its usually the ECM not re-programmed properly (no operating control re-mapping), and still trying to make extra friction and heat to try to warm up a DPF can that is no longer in place. This is extremely hard on the cylinders internally and eventually leads to dropped (fretted) liners and blown head gasket.
- Start by copying the program from the ecm and e-mailing it to me to get a review of what someone did in there.
info: https://rawze.com/forums/showthread.php?...5#pid72945
 Thanks given by: thewondershowzen
06-29-2025, (Subject: bad de-mandated programming )
I'm having the same issue Rawze w/my X15 605hp. Almost exactly the same. What is your email address and I how do I copy the file?
Yesterday, (Subject: bad de-mandated programming )
(06-29-2025 )CountyLine61 Wrote:  I'm having the same issue Rawze w/my X15 605hp. Almost exactly the same. What is your email address and I how do I copy the file?
Read the previous post, there is link where those instructions are.
 Thanks given by: CountyLine61
The link above shows how to copy the file out.
and like the post in the link above says...
Any program for review should be sent to 'Rawze' '@' 'protonmail.com' where someone should also PM me and let me know they have sent me a program for review, etc.
 Thanks given by: CountyLine61 , thewondershowzen
