derate 3712, 3714, 2976 |
08-27-2025, (Subject: derate 3712, 3714, 2976 ) Post: #1 | |||
derate 3712, 3714, 2976 Hello, 2015 ISL9 here. Changed out my NOX and doser unit (genuine cummin) to get rid of some codes and it did, but left with these three now. Ran a regen, completed, codes still there. Ran an SCR test, eventually truck shuts off, Aftertreatment Warm Up an DEF dosing test says stopped, check status window, but status window just says Running. Ive been reading and some suggest updating the ECU, or maybe the doser pump for the 2976 code. Flashing this truck is unfortunately not an option, as it needs to be passing the biannual CA smog check. Thanks for your help. | |||
08-27-2025, (Subject: derate 3712, 3714, 2976 ) Post: #2 | |||
RE: derate 3712, 3714, 2976 Yea update the ECM, if it has the original program in it from 2015 it's very outdated and the newest file could have fixes for some of those codes you mentioned. | |||
08-28-2025, (Subject: derate 3712, 3714, 2976 ) Post: #3 | |||
RE: derate 3712, 3714, 2976 ... and while you are at it, do a full EGR tune-up on it as well... http://rawze.com/forums/showthread.php?t...30#pid7030 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
Yesterday, (Subject: derate 3712, 3714, 2976 ) Post: #4 | |||
RE: derate 3712, 3714, 2976 Thanks question In quickserve and my ESN, under Service, Related Information, I dont see Calibration Downloads. ---Service Applications Agility Fuel Systems – Parts and Service Information External LinkCummins Clean Fuel Technologies SPN/FMI To Cummins Fault Code Cross-Reference ---Service Documents Archived Service Parts Topics Regulatory Documents these are my only options. Do I need a paid account? I am only using one ESN out of 5 slots. Thanks! | |||
Yesterday, (Subject: derate 3712, 3714, 2976 ) Post: #5 | |||
RE: derate 3712, 3714, 2976 You need a paid account to get them that way. You can get them for free here... https://www.cummins.com/support/digital-...al-support What program do you have right now? | |||
Yesterday, (Subject: derate 3712, 3714, 2976 ) Post: #6 | |||
RE: derate 3712, 3714, 2976 Thanks! I am using Cummins Insite. I see 13 disks available for download, is this correct? Will I be able to see which cal applies to my engine? | |||
Today, (Subject: derate 3712, 3714, 2976 ) Post: #7 | |||
RE: derate 3712, 3714, 2976 (Yesterday )montrose818 Wrote: Thanks! I am using Cummins Insite. Yes, 13+ disks. Its Unknown as to which one has your specific calibration on it, so you might have to download them all to find it. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
