Farm Dump Truck Mechanic Simulator Demandate
09-04-2025, (Subject: Farm Dump Truck Mechanic Simulator Demandate )
First post! Please don't ban me for adding some odd humor. Serious post.
I recently started playing farm Dump truck simulator and the truck started have issues with the exhaust accessories. The game is super duper realistic.
Anyway, 2011 Pete 365 with CM2250, isx15, Sr no 79429715 (in a video game! I know... Such realism).
Had some codes and went full derate. Reset codes and some have not come back, but some probably will come back.
Codes in photo.
Tried to do a forced Regen, but dosing unit stayed in initializing state.
In farm Dump truck simulator, you idle a lot. It's truly inappropriate, but it can't be helped.
So I think this is the part of the game where you have to Demandate to reach the next level.
I'm learning and reading a lot presently.
Is this Amazon item below a compatible game controller? I also read about Nexiq USB link 2?
Ready to place an order and get to next step, but need advice.
Thanks in advance!
-T
Brand: Tooihteo
3.8 out of 5 stars
(24)
Inline 6 Data Link Adapter Full kit Fit for Cummins Engine J1939 J1708 Protocols Aftermarket Tool
RE: Farm Dump Truck Mechanic Simulator Demandate
You will want something like this one if you only plan to use it on a Cummins.
https://ebay.us/m/aWzFp3
and as far as the de-mandade programming... maybe this post helps...
https://rawze.com/forums/showthread.php?...2#pid81862
Nexiq only works fine if original from a reputable source.
Cheap 100usd Inline6 from china has worked excellent for me compared to nexiq look a like that looses connection often and so on.
First things first. You need to verify that sensors are working correctly (most important are back pressure and IMAP). If those sensors are painted red then those are factory originals. Use only original parts, aftermarket junk sensors are quaranteed problems. You need to get engine running properly whether or not you will mandete'd or not.
Here is more info what to do first.
https://rawze.com/forums/showthread.php?...pid=9#pid9
(09-04-2025 )mikkhh Wrote:  Nexiq only works fine if original from a reputable source.
First things first. You need to verify that sensors are working correctly (most important are back pressure and IMAP). If those sensors are painted red then those are factory originals. It means just replace them and forget about them. If you have inline diagnostic and have time you can clean old sensors with brush and like 1bar of air from compressor and then see if they read same as new ones, if they do keep them as spares Use only original parts, aftermarket junk sensors are quaranteed problems. You need to get engine running properly whether or not you will mandete'd or not.
