Code 3165 and 418 cm2250
10-21-2016, (Subject: Code 3165 and 418 cm2250 )
Code 3165
Aftertreatment SCR Outlet Temperature - Data Valid But Above Normal Operational Range - Most Severe Level. The selective catalytic reduction (SCR) outlet temperature sensor reading has exceeded the maximum temperature limit.
Code 418
Water-in-Fuel Indicator - Data Valid But Above Normal Operating Range - Least Severe Level. Water has been detected in the fuel filter.
Just changed water fuel separator about 18k miles ago....
RE: Code 3165 and 418 cm2250
How often is this truck serviced? Is the truck on any type of service interval program, did anyone put def in the fuel tank?
Also what is the going rate for these two codes? Just one count for each
I service the truck every 12-13k miles. I shut the truck off and turned it back on let it idle for 1 min and it went away. That's what insite said to do. I will replace the fuel water separator filter when I get a chance.
