|  The right insite  |
|  01-27-2018, (Subject: The right insite )  Post: #1 | |||
| The right insite  I have 2010 kenworth T800. I finally got the cash to buy the inste 5 from ebay. I want to make sure I buy the right one. I want to do a force regent and be able to trouble shoot. Can i get some help on the right on-site I need. Thanks  | |||
|  01-28-2018, (Subject: The right insite )  Post: #2 | |||
| RE: The right insite  Inline 5 adapter will work and you'll need at least Insite version 7.6.2 with service pack 5. Most of those ebay buys are fine and come with all the hardware and software. Although the service pack 5 or SP5 usually isn't with the chinese knock offs. SP5 update I know corrected a problem with being able to cut out multiple single injectors during an injector cut out test. So you'll probably want that or track it down. Its just an update to 7.6.2  | |||
