2 cylinder fuel pump camshaft
03-02-2018, (Subject: 2 cylinder fuel pump camshaft )
Does anyone have a picture of the camshaft on one of these pumps? I bought a used working takeoff. One of the camshaft lobes has a valley in it. I'm just trying to make sure it's not designed that way. The camshaft doesn't appear to be damaged. I'm just trying to figure out if it's any good or if I should return it. I was going to rebuild it if the camshaft was good. Thanks.
RE: 2 cylinder fuel pump camshaft
(03-02-2018 )aaronb Wrote:  Does anyone have a picture of the camshaft on one of these pumps? I bought a used working takeoff. One of the camshaft lobes has a valley in it. I'm just trying to make sure it's not designed that way. The camshaft doesn't appear to be damaged. I'm just trying to figure out if it's any good or if I should return it. I was going to rebuild it if the camshaft was good. Thanks.
Refer to cummins quickserve.
./uploads/201803/post_1794_1520021253_7a5a018878ebc36fabf337fe66663ab0.png
 Thanks given by: Rawze , hhow55
03-04-2018, (Subject: 2 cylinder fuel pump camshaft )
If you post a pic of the camshaft there are more than enough people on here to tell you if it's a pass or a fail.
03-14-2018, (Subject: 2 cylinder fuel pump camshaft )
Rebuild? I have one also. Where can you get parts? Cummins quickserve shows replacing pump is only option?
