|  Turbo drive pressure  |
|  04-05-2018, (Subject: Turbo drive pressure )  Post: #1 | |||
| Turbo drive pressure  Has anyone installed a gauge to read drive pressure on a stock turbo? What kind of numbers have you seen? Stock and demandated  | |||
|  04-05-2018, (Subject: Turbo drive pressure )  Post: #2 | |||
| RE: Turbo drive pressure (04-05-2018 )bulldog77 Wrote: Has anyone installed a gauge to read drive pressure on a stock turbo? What kind of numbers have you seen? Stock and demandated IIRC, you have an 870. The turbo efficiency of them is around 1.8:1, so it should be intake pressure times about 1.8. A turbo pushing 38psi max will be in the ~68psi exhaust manifold range. User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
|  04-06-2018, (Subject: Turbo drive pressure )  Post: #3 | |||
| RE: Turbo drive pressure  One should be able to monitor drive pressure with Insite?  User's Signature: The fastest way to learn is to make a mistake. If it costs me $ I learn pretty quickly. It's cheaper to learn from someone else's mistakes. | |||
|  04-06-2018, (Subject: Turbo drive pressure )  Post: #4 | |||
| RE: Turbo drive pressure (04-05-2018 )Hammerhead Wrote:(04-05-2018 )bulldog77 Wrote: Has anyone installed a gauge to read drive pressure on a stock turbo? What kind of numbers have you seen? Stock and demandated Are those real world numbers or what Holset says? Maybe in some spare time(lmao) I should hook up a gauge and see. | |||
|  04-07-2018, (Subject: Turbo drive pressure )  Post: #5 | |||
| RE: Turbo drive pressure  CM871 measured, no EGR gas flow ... NOTE: All exhaust pressures data is after subtracting 14.1 psi from the sensor because it reads atmosphere+ unlike the boost sensor which reads zero when at rest. At idle with turbo at only 15% (slight vacuum), adjusted to absolute minimal fuel consumption ... -- Exhaust pressure = 0.7 -- Intake pressure = 0.03 psi (Ratio = 23:1 - Inaccurate, cannot be measured by the sensors). -- Turbocharger rpm = 11.4k -- fuel flow = 13.7 mg/stroke At 52 hp, 1240 rpm, cruising with light torque load ... -- Exhaust pressure = 6.5 psi -- Intake pressure = 0.89 psi (Ratio = 7.3:1 - Terrible at little to no load or boost requirement). -- Turbocharger rpm = 30.8k -- fuel flow = 59.2 mg/stroke At 412 HP, 1360 rpm, steady 90% engine load (close to full throttle) ... -- Exhaust pressure = 47.4 lbs -- Intake pressure = 19.7 lbs (Ratio = 2.53:1 - a more realistic measurement). -- Turbocharger rpm = 94.3k -- fuel flow = 274.4 mg/stroke At 412 HP, 1630 rpm, accelerating bobtail ... -- Exhaust pressure = 50.6 lbs -- Intake pressure = 29.9 lbs (Ratio = 1.69:1 - about as good as it gets). -- Turbocharger rpm = 96.4k -- fuel flow = 240.2 mg/stroke === I have seen 70+ PSI in the exhaust manifolds many times and as much as 90+ on high HP engines when rapidly shifting them during surge. Combine that with a lot of heat and you find out why an EGR cooler or egr component can fail if it is weak. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
|  04-07-2018, (Subject: Turbo drive pressure )  Post: #6 | |||
| RE: Turbo drive pressure  Thanks for sharing. It's great to see honest real world numbers or what happens.  User's Signature: The fastest way to learn is to make a mistake. If it costs me $ I learn pretty quickly. It's cheaper to learn from someone else's mistakes. | |||
