Which pressure tester? |
01-06-2019, (Subject: Which pressure tester? ) Post: #1 | |||
Which pressure tester? Which tester do you guys use? Obviously Amazon and ebay sell them but is there a certain one that comes with the correct adapters or are they all the same? User's Signature: im_seeing_parameters_in_my_sleep 1 | |||
01-06-2019, (Subject: Which pressure tester? ) Post: #2 | |||
RE: Which pressure tester? | |||
01-06-2019, (Subject: Which pressure tester? ) Post: #3 | |||
RE: Which pressure tester? I use these, identical to the Snap-on unit I have seen. I'm sure Stant makes them for Snap-On. Hand pressure pump, with case. https://amzn.to/2GYOdin Stant adapter for ProStar with ISX. Also works on some GM and Ford vehicles. https://amzn.to/2GXDt3u | |||
