| Oil return plugs in block |
| 07-20-2019, (Subject: Oil return plugs in block ) Post: #1 | |||
| The oil return plugs on the side of the block....anyone know what thread pitch they are? Metric pipe thread or o-ring type seal? Tried getting mine out and think I'm gonna have to put some heat on it...to get it loose. | |||
| 07-20-2019, (Subject: Oil return plugs in block ) Post: #2 | |||
| RE: Oil return plugs in block you have to use an Allen socket + breaker-bar + smack the breaker-bar with a 2-lb hammer with quite a bit of force... they will break free quite well like that. at 12:18 in this video, i break free one of the small allen plugs in the intake manifold,.. same principle, only the one in the video is on a smaller scale... https://youtu.be/lUeYsQY0ykM User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 07-21-2019, (Subject: Oil return plugs in block ) Post: #3 | |||
| RE: Oil return plugs in block All the plugs in the ISX with an Allen head are metric oring seal with a 1.5 pitch. | |||
