Help low boost
02-25-2016, (Subject: Help low boost )
Post: #37
RE: Help low boost
wd40 and spray couple days , you dont want to brake those rusty bolts
Post: #38
RE: Help low boost
Yea I'm gonna try but the look really bad
Post: #39
RE: Help low boost
(02-25-2016 )gonzo1949 Wrote:  Yea I'm gonna try but the look really bad
ATF with acetone 50%x50% mix. working good.
Post: #40
RE: Help low boost
I would say that you may have to put socket on then stick with hammer. I would also use a impact hand driver with a socket the shock my get it. I think the biggest problem is that bolts will be siezed in the actutor because it's aluminum.
02-27-2016, (Subject: Help low boost )
Post: #41
RE: Help low boost
./uploads/201602/post_824_1456606684_2ddb432b4e9d9a2995d7e2164e8fa779.jpg
So this was the issue. I pulled off the actuator and ran the install procedure and it failed. Turbo was ok and moved nice and smooth.picked up the actuator for 436.00 at the local cummins dealed. Install went smoothly and truck is running great.I wanna thank everyone for the help and advice.
02-28-2016, (Subject: Help low boost )
Post: #42
RE: Help low boost
The thing that concerns me is ne codes that bad actuator should have lit up the dash like a christmas tree.
Post: #43
RE: Help low boost
(02-28-2016 )gearhead Wrote:  The thing that concerns me is ne codes that bad actuator should have lit up the dash like a christmas tree.
I saw this many times , no code no warning lights just silent derate. Some trucks had this code suppressed via c@lternn.
Post: #44
RE: Help low boost
Yea I thought it was strange it didn't give me any codes. If it wasn't for the boost gauge I wouldn't have noticed until I got a heavy load which I don't do many of.
Post: #45
RE: Help low boost
It is not factory block i can tell you that. I have never seen this fault blocked from factory.
