cm870 proper de-mandate
02-27-2020, (Subject: cm870 proper de-mandate )
Who should I talk to about a proper de-mandated program for cm870? I have insite and can put the programs in but I really don't know much about it.
RE: cm870 proper de-mandate
Mommaburt or unilevers
 Thanks given by: tdawg
(02-27-2020 )Squish099 Wrote:  Mommaburt or unilevers
Have one of those guys do it for you. The 870 ecm is very unstable and if you don't know what your doing you can brick it while trying to flash in a file. 871 and newer engine's don't have this problem. Also there isn't an overlay available for the 870, some parameters must be live edited.
 Thanks given by: hhow55
I would consider having Mr Hagg program a new ecm for you, since they are unstable.
 Thanks given by: tree98
mommaburt, unilevers, or take it to mr. hag for some solid, reliable solutions.
Mommaburt is the man to hit up for this. We just got done tweaking mine and I'm now seeing mid to high 7's mpg consistently.
02-28-2020, (Subject: cm870 proper de-mandate )
(02-27-2020 )Chamberpains Wrote:  Mommaburt is the man to hit up for this. We just got done tweaking mine and I'm now seeing mid to high 7's mpg consistently.
Did you send your ecm to him?
Those guys work on your ecm remotely, you don't even take it off the truck. All you need is an internet connection, laptop with insite and an inline adapter and the magic happens !!
 Thanks given by: tdawg , Blueovalnut
