Boost pressure check engine engine light |
03-04-2020, (Subject: Boost pressure check engine engine light ) Post: #10 | |||
RE: Boost pressure check engine engine light That’s what it says on my dash .. saying boost pressure... and my truck has dpf delete.. I’m also going to check the other things tree98 suggested .. | |||
03-04-2020, (Subject: Boost pressure check engine engine light ) Post: #11 | |||
RE: Boost pressure check engine engine light You did not mention what your "normal boost pressure" is. points right back to this: http://rawze.com/forums/showthread.php?t...2#pid50802 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
03-04-2020, (Subject: Boost pressure check engine engine light ) Post: #12 | |||
RE: Boost pressure check engine engine light Boost pressure is about 5 psi when unloaded on flat rd and about 5-10 psi when I’m loaded on flat rd and when going up a slight hill or something it hits about 20-25 psi loaded | |||
03-04-2020, (Subject: Boost pressure check engine engine light ) Post: #13 | |||
RE: Boost pressure check engine engine light That's too low, unless your driving it that way intentionally. Why don't you get your program checked out before you go any further? User's Signature: im_seeing_parameters_in_my_sleep 1 | |||
