Rod cap bolt torque
03-27-2020, (Subject: Rod cap bolt torque )
Rod cap bolt torque
What are you guys doing to get the “60 degrees” accurately [/font]for final torque on the rod cap bolts? 180 was easy enough to mark on the mains, but how did you accurately mark 60 degrees on the rod cap bolts?? Thanks
RE: Rod cap bolt torque
60-degrees is the rotation of one flat-side to the next on a 6-point bolt head, or 2-flats on a 12-point bolt head.
 Thanks given by: JMBT , tree98 , hhow55
perfect! thanks Rawze
