First dryvan purchase
06-01-2020, (Subject: First dryvan purchase )
Buying my first dryvan...
Looking at a 2006 Great Dane plate trailer....it has a aluminum floor....should I stay away or are they ok?
RE: First dryvan purchase
just don't put a 40k coil in the center of the deck and you should be ok.
Alot of places have age requirements on van trailers. So if you have any plans of automotive or food grade I would look for newer.
We pull some tank trailers that are made in the 1970's. Ha
How old is too old on van trailers?
Automotive, well GM says 10 years and they look every time you drive to the gate.
 Thanks given by: Mattman
06-03-2020, (Subject: First dryvan purchase )
If floor gets wet it won't dry very well can be very slippery if you are in well dock can be hard to drive forklift in.
