ISX wont start |
08-04-2020, (Subject: ISX wont start ) Post: #1 | |||
ISX wont start Hi Guys, Newbie here. I've got a problem with one of my trucks- a 2008 pete 379 with an ISX CM871 engine. The truck was left sitting for more than a month and it wont start now but cranks really good. We tried checking and changing the fuel pump, put pressure on the tank, check all the fuses and check the timing but, unfortunately, still wont start. Anything I missed checking? Thanks | |||
08-04-2020, (Subject: ISX wont start ) Post: #2 | |||
RE: ISX wont start Fuel shut off solenoid? User's Signature: im_seeing_parameters_in_my_sleep 1 | |||
08-04-2020, (Subject: ISX wont start ) Post: #3 | |||
RE: ISX wont start I'll check it. Thanks | |||
08-04-2020, (Subject: ISX wont start ) Post: #4 | |||
RE: ISX wont start Are the fuel filters full? | |||
08-04-2020, (Subject: ISX wont start ) Post: #5 | |||
RE: ISX wont start Check for crank and cam timing sensor User's Signature: One word not enough two words to much to say | |||
08-04-2020, (Subject: ISX wont start ) Post: #6 | |||
RE: ISX wont start | |||
08-04-2020, (Subject: ISX wont start ) Post: #7 | |||
08-04-2020, (Subject: ISX wont start ) Post: #8 | |||
RE: ISX wont start when you turn the key on does the electric pump run for 2 minutes? While the electric pump is running, has anyone bothered to bleed the compu-check port worth at least couple quarts worth of fuel to get all the air out? lastly,.. in insite,...how many psi while cranking? -- ref: http://rawze.com/forums/showthread.php?t...23#pid8423 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
