Paccar ESA NavPlus
10-31-2020, (Subject: Paccar ESA NavPlus )
Paccar ESA NavPlus
Hi guys.
To clear things up I got a 2015 W900 and it has the NavPlus display module and it went bad on me. So I picked up a used one from a buddy and it works for the most part but when I try to connect to it with Paccar ESA its giving me a Vin Miss-Matched error. When I click on the "fix" button it closes the connection. Any ideas on what it takes to fix that?
./uploads/202010/post_5164_1604182707_dd0fbff1075f196bbcc77516422dca81.jpg
11-08-2020, (Subject: Paccar ESA NavPlus )
RE: Paccar ESA NavPlus
Have you flashed your CECU with the latest software in ESA? I've had luck doing that and then re-entering ESA to fix radio programming like that.
11-20-2020, (Subject: Paccar ESA NavPlus )
Yes i flashed it to the latest update
