CM2250 Vibratech Damper
11-25-2020, (Subject: CM2250 Vibratech Damper )
I see that Vibratech has released a new heavy duty version of the damper in addition to the stock replacement. {link removed}
When is it suggested here on when it is it better to upgrade to the hd unit as opposed to the stock replacement?
RE: CM2250 Vibratech Damper
(11-25-2020 )redbeard Wrote:  I see that Vibratech has released a new heavy duty version of the damper in addition to the stock replacement. {link removed}
some of the ppl that have them say they are ok, make no difference from factory unit.. others have had to rip them off because they went bad prematurely. .. I am not a fan of them myself.
otherwise, stop listening to the market hype ... companies will do anything to get you to buy their s$it.
here is one of those references: http://rawze.com/forums/showthread.php?t...5#pid11905
 Thanks given by: redbeard
11-26-2020, (Subject: CM2250 Vibratech Damper )
All a damper does is balance the crankshaft, 500,000 mile life span, I can't see what would make one HD? It is the viscous fluid in them internally that drys and hardens over time, not the damper itself. I would stick with the tried and true OEM from Cummins. Remember to paint it.
