| Data plate on valve cover? |
| 03-19-2021, (Subject: Data plate on valve cover? ) Post: #1 | |||
| Data plate on valve cover? Is it possible to get another data plate i can't read mine anymore. If so how can I get one? | |||
| 03-19-2021, (Subject: Data plate on valve cover? ) Post: #2 | |||
| RE: Data plate on valve cover? Cummins but be ready to pay out the nose..... | |||
| 03-19-2021, (Subject: Data plate on valve cover? ) Post: #3 | |||
| RE: Data plate on valve cover? Any idea on pricing? | |||
| 03-19-2021, (Subject: Data plate on valve cover? ) Post: #4 | |||
| RE: Data plate on valve cover? Cummins quickserve.cummins.com, a call to the dealership for the info and a sharpie is way cheaper and easier. | |||
| 03-19-2021, (Subject: Data plate on valve cover? ) Post: #5 | |||
| RE: Data plate on valve cover? If I remember correctly its $ 500 for that plate, so like Chamber said there are cheaper and easier ways. | |||
| 03-19-2021, (Subject: Data plate on valve cover? ) Post: #6 | |||
| RE: Data plate on valve cover? Wow $500. I guess I won't be doing that good thing I have the ESN number | |||
| 06-24-2021, (Subject: Data plate on valve cover? ) Post: #7 | |||
| RE: Data plate on valve cover? | |||
| 06-24-2021, (Subject: Data plate on valve cover? ) Post: #8 | |||
| RE: Data plate on valve cover? Depends on what info your looking for. But if has anything to do with the ESN you have then quickserve.cummins.com will have it. If you don't have the ESN for the truck then a call to the dealership and they can give you the ESN of the factory original engine. | |||
