Flywheel vibration?
04-24-2021, (Subject: Flywheel vibration? )
Post: #19
RE: Flywheel vibration?
So it turns out that the first mechanic was a dishonest POS.The second mechanic said all that was needed was the clutch adjusted and that the clutch was fine.
Post: #20
(04-24-2021 )Redland1 Wrote:  So it turns out that the first mechanic was a dishonest POS.The second mechanic said all that was needed was the clutch adjusted and that the clutch was fine.
A common tale... Good to hear it was something simple!
 Thanks given by: Redland1
