International 9900i oil temperature gauge replacement
04-28-2021, (Subject: International 9900i oil temperature gauge replacement )
RE: International 9900i oil temperature gauge replacement
(04-20-2021 )Redland1 Wrote:
(04-20-2021 )Luckyjayb Wrote:  I have replaced mine with factory ones
I found a used one on eBay.Where did you order yours from?
eBay as well. If it wasn’t the engine oil temp, I got a spare trans, diffs, fuel, and primary and secondary air gauges with the white background if you need them
 Thanks given by: Redland1
I replaced it but it’s still not working.Wondering if it’s an issue with the dash.
(04-28-2021 )Redland1 Wrote:  I replaced it but it’s still not working.Wondering if it’s an issue with the dash.
Might be the board on the back of the dash panel. I ordered a whole panel assembly off eBay for the one to the right of my steering wheel to get my gauges to work properly (that’s why I have the spare gauges). It could also be the wires at the sensor are broke. That’s what was wrong with my oil temp sensor. I hooked em up and tested it out and had to swap the wires around bc the dang things are the same color and they have to be hooked up right to work. I think a limb or something is what tore mine.
