Isx15 motor needs more get up and go
04-25-2021, (Subject: Isx15 motor needs more get up and go )
RE: Isx15 motor needs more get up and go
It was replaced with new parts before it came apart
(04-25-2021 )Cornbreadtrucker Wrote:  It was replaced with new parts before it came apart
u sure it has less than 400k miles on it?.. if not then u need to replace its guts.
Yes has around 60,000 miles on new parts. They was nothing wrong with it when I had it taken apart and parts replaced. I did get registered with cummins insite and the motor is a isx15 450st.
05-04-2021, (Subject: Isx15 motor needs more get up and go )
Just want to chime in, for the OP or anyone else reading. When talking about "load" we're referring to engine load, not cargo load. How hard the engine has to work. Yes, there is some correlation between the 2, but they are not the same thing. Just wanted to clarify that, as it's mentioned frequently here but with the assumption that everyone understands the terminology.
User's Signature: Think for yourself. Question authority.
