Priming oil system
04-24-2021, (Subject: Priming oil system )
Priming oil system
Hey fellas , is there a better location to prime oil system
After servicing the bearings. I know they mention
through the oil cooler center plug on quick- serv .
Tks a lot ,
RE: Priming oil system
I use the bypass valve fitting just above the oil filter housing with bypass valve removed temporarily...
I show it at 1:50 in this video:
https://odysee.com/@rawze:d/isx-engine-r...be-turbo:5
 Thanks given by: Pd6cas2
Thank you . Much appreciated.
(04-24-2021 )Rawze Wrote:  I use the bypass valve fitting just above the oil filter housing with bypass valve removed temporarily...
Hey rawze, appreciate it . I just shopped in your
Amazon of. There’s alot of useful tools on there.
04-25-2021, (Subject: Priming oil system )
Rawze, it appears in that video you painted the oil return line for the turbo red. If you did, how has the paint held up? Did it end up getting burnt off and the line rusted up any way?
(04-25-2021 )Chamberpains Wrote:  Rawze, it appears in that video you painted the oil return line for the turbo red. If you did, how has the paint held up? Did it end up getting burnt off and the line rusted up any way?
i re-used the old pipe. That line to this day is still the original one from when engine was new.
 Thanks given by: Chamberpains
