| cm2350 |
| 04-27-2021, (Subject: cm2350 ) Post: #1 | |||
| cm2350 anyone know the size of the injector line caps for the cm2350 example inner diameter - m18 thread interval - 1.5 trying to source a cheaper method than cummins for injector block off caps. i see the 6.7cummins uses the m18 1.5 idk if thats the same or smaller or what and it is also a 2000 bar system like the ISX. User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
| 04-27-2021, (Subject: cm2350 ) Post: #2 | |||
| RE: cm2350 Id be interested as well, running as isc, not sure if the rail, etc are the same. | |||
| 04-27-2021, (Subject: cm2350 ) Post: #3 | |||
RE: cm2350 (04-27-2021 )Lonestar10 Wrote: anyone know the size of the injector line caps for the cm2350One connector pipe from rail to injector. Cut in half, weld the end. | |||
| 04-28-2021, (Subject: cm2350 ) Post: #4 | |||
| RE: cm2350 A local machine shop made them for me 60 bucks for all six They just had me bring them a fuel line to model the plug off of | |||
| 04-28-2021, (Subject: cm2350 ) Post: #5 | |||
| RE: cm2350 Your dealing with pressures that can kill or seriously injury you!!!! Don't take chances just buy them from cummins. | |||
| 04-28-2021, (Subject: cm2350 ) Post: #6 | |||
| RE: cm2350 I know all about hydraulic injection. But Cummins most likely has these made by miller as that's who makes them for Cummins for the 6.7 liter. The miller 9864a is the part for a 6.7 cap. At about $20 a cap vs the 100+ per cap from Cummins. User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
| 06-22-2021, (Subject: cm2350 ) Post: #7 | |||
RE: cm2350 (04-28-2021 )Lonestar10 Wrote: I know all about hydraulic injection. But Cummins most likely has these made by miller as that's who makes them for Cummins for the 6.7 liter. The miller 9864a is the part for a 6.7 cap. At about $20 a cap vs the 100+ per cap from Cummins. Curious if there’s any updates on this? User's Signature: Born and raised in Vyskonsin on milk, cheese, bread, and beer! | |||
