OIL Faves?
06-08-2021, (Subject: OIL Faves? )
RE: OIL Faves?
I can tell on my cm871 when then oil pressure drops 2 psi off of a fresh oil change. At ~1500 rpm it sits at 38-41 when fresh and when it gets time to change it drops 36-39 psi. Usually spot on to 12,000-15000 miles.
On my cm870 it told me by getting more chattery and breathing a bit heavier out the blow by. Fell right in the same mileage range.
06-09-2021, (Subject: OIL Faves? )
RE: OIL Faves?
Ive done Delo but willing to switch to rotella :)
RE: OIL Faves?
Rotella and gear oil here. I can tell when it is time to change oil.
RE: OIL Faves?
Delo 400 and super tech gear oil for the last 500k. No issues.
RE: OIL Faves?
same as Nilao, Delo 15w40 and Super Tech 80w90.
Like the other guys I've begun to get a feel for when it needs changing. Sounds a little different. In fact it just transitioned a day or so ago. Also track my fuel mileage in a spreadsheet and it automatically calculates my next target oil change based on my running mpg average for that oil. Just so happens I hit that exact mileage interval today too. Unfortunately the oil and gear lube won't be delivered until saturday so she's gotta hold out another 700-800 miles. Roughly 16,000 on this oil, demandated and only slightly darker then when it went in.
For the record, I can also hear the difference when I get about 2 quarts down from the full line on the dipstick.
User's Signature: "The sky above the port was the color of television, tuned to a dead channel." – William Gibson, Neuromancer
