Actuator coolant return housing
06-26-2021, (Subject: Actuator coolant return housing )
Well removed the turbo a couple weeks ago, and notice coolant was getting low
Well finally found the cause. It was the turbo actuator housing,right under
The threads where the banjo screws into. Any ideal if someone just sells actuator coolant housing ?
Tku in advance
RE: Actuator coolant return housing
(06-26-2021 )Mrt800 Wrote:  Well removed the turbo a couple weeks ago, and notice coolant was getting low
Tku in advance
can probably just replace the gasket. or find another bad actuator and steal the one from it.
06-27-2021, (Subject: Actuator coolant return housing )
Yeah I watch that series of videos,awesome stuff.
It’s looking like I’ll be buying a new actuator.
I’ve been searching.
