2636/SPN 641 FMI 9
06-27-2023, (Subject: 2636/SPN 641 FMI 9 )
RE: 2636/SPN 641 FMI 9
(06-25-2023 )Rawze Wrote:
(06-24-2023 )Cornhauler2 Wrote:
(06-24-2023 )ktblogistics Wrote:  key turned off
unplug actuator
should have 120ohm on actuator side and 120ohm on harness side
So I have 120 on the harness side and 45k on the actuator side.
actuator should have 120 ohms too.
Is this a replacement actuator that was purchased somewhere and not from the OEM/stealert$it?.
I ask that because Volvo Actuators do not have the 120-ohm resistor in them, and they look identical to a cummins because they are both Holset brand.
As far as I know it’s original to the engine. I’ve put about 60k miles on it around the farm since we bought it 3 years ago and it just suddenly started with the check engine light then the stop engine light with the codes I listed.
06-29-2023, (Subject: 2636/SPN 641 FMI 9 )
UPDATE… I put a new actuator on and the check engine light immediately went away and it’s back to no codes, active or inactive.
Also Rawze, the old actuator had a RX part number so it wasn’t original. But it had been on the turbo a long time.
(06-29-2023 )Cornhauler2 Wrote:  ..
Thanks for the update.
Now .. you need to find out what caused that terminating resistor to fail like that. Things like ...
** Someone using high-power (cb or ham) radio gear that is not grounded properly?.
** Alternator noise is higher than normal due to leaky/weak diodes internally?.
** One of those crappy square-wave, or modified-sine-wave truck stop Power inverters?.
-== You get the picture.
