| coolant hose bracket insert |
| 04-13-2024, (Subject: coolant hose bracket insert ) Post: #1 | |||
| coolant hose bracket insert There is a bolt or plug missing from this bracket, this hole is on the bottom of the block but I cant figure out what is exactly. it is there to keep the coolant hose steady. Does anyone knows a part number or anything i can retro fit. thanks. truck is 05 9900 eagle Isx cm870. see images for reference | |||
