Pete & KW related Help...
Threads
- High Air Filter Restriction (1 Reply)
- Pete 579 2017 auto transmission issue (4 Replies)
- No start, no cab power issue (2 Replies)
- Frequent regens (5 Replies)
- 2007 379 fan runs all the time (7 Replies)
- Pete 386 Electrical Issue gauges losing power (7 Replies)
- Wiring Harness (2 Replies)
- Paccar ESA gauge issue (0 Replies)
- PACCAR ESA 5.6 (2 Replies)
- Losing engine gauges, speedo, and fan staying on (10 Replies)
- 2009 cm 871 has us stumped (3 Replies)
- T880 won't overinflate, any ideas where to start (2 Replies)
- 2013 KW T660 PACCAR CODE HELP (1 Reply)
- CM871 to CM570 Odometer Issue (6 Replies)
- vibration damper thoughts (63 Replies)
- T880/Endurant kicks into neutral (9 Replies)
- Paccar fuel filter doesn't stay full (25 Replies)
- 2012 KW t800 outside air temperature sensor (1 Reply)
- Throttle Position Sensor Problems - Solving them. (14 Replies)
- No start (2 Replies)
- Jake switch settings in Esa (17 Replies)
- 09’ KW T800 CECU (4 Replies)
- 2010 KW T660 visor lights stay on with key off (4 Replies)
- Kenworth AG400 suspension rebuild (2 Replies)
- Autoshift to 18Speed manual (6 Replies)
