Full Version: HVAC Blower motor issues. 2008 Prostar
Pages: 1 2
Alright guys! The HVAC front blower motor only runs when it wants, usually at low speed. I have replaced all fuses, breakers, the spiked resistor/module, everything related except for the blower motor itself... Any of you guys have this problem before? Sitting, the blower will not run. I start driving, the blower runs, but only when it wants. It will run on high for a minute or two and then shut off... Filter is fine. Took it to dealer, no codes. I was just under the dash, wiring looks good, as do connectors. Going to put old working blower motor in tomorrow, when it quits raining here and try that. Any help appreciated.
It's the motor. Mine was doing that. I reached in and squeezed the rubber covers over the brushes and it came to life. Replaced it and tore old one apart to see it and it was actually the commutator copper was completely worn off except for 2 or 3 contacts.
A while back I posted with the same issue you describe. you suggested fuses... turned out to be my motor on its last leg because weeks later it died all together.
In other news, when I got it all back together ... it wouldnt go higher then setting 3 without cutting out like it was overheating or something. Changed the fuse and it's perfect now!
(10-20-2016 )Brock Wrote: [ -> ]A while back I posted with the same issue you describe. you suggested fuses... turned out to be my motor on its last leg because weeks later it died all together.
I'm thinking motor too... Damn things don't last very long, it is only two years old.
It was the motor, bearings were shot... $171.00 for the blower motor, just installed and now fixed.
I'm glad you posted that message Brock. Mine cuts out when used at high speed, so I just don't run it over 1/2 speed and all is good. I was thinking eventually I might have to replace that spiky controller; replacing the breaker never crossed my mind.
(10-21-2016 )barf Wrote: [ -> ]I'm glad you posted that message Brock. Mine cuts out when used at high speed, so I just don't run it over 1/2 speed and all is good. I was thinking eventually I might have to replace that spiky controller; replacing the breaker never crossed my mind.
I bought my spikey thing from these guys... http://www.truckerac.com/blower-resistor...21021.html
I also bought the one for the bunk, the resistor, it solved the issue I was having back there.
It was half the price of what the dealer wanted, made by Behr, works and fit perfectly. He was out of blower motors until December... Or I would have bought mine there when I bought the resistor.
On the breaker, pull it and replace it with a regular 30 amp fuse. Replace fuse a couple times a year, as they tend to overheat... They are cheaper than new breakers. The ProStars are notorious for overheating this particular fuse/breaker.
The blend door stopped working on mine. it was the output gear that cracked inside the motor controller.
so I made a new one myself using my 3d printer ...
[attachment=2121]
Even though all mine is new and works perfectly fine, I've still got a code that says hvac motor in wrong position or jammed.
also says my rear hvac actuator position not responding.
Pages: 1 2
Reference URL's
