11-16-2016,
I am thinking any engine of the same era could be equal to the hyper mile trophy or at least tie? Especially if driven by Rawze. Just a theory I've been pondering.
(11-16-2016 )Jarhead79 Wrote: [ -> ]I am thinking any engine of the same era could be equal to the hyper mile trophy or at least tie? Especially if driven by Rawze. Just a theory I've been pondering.
(11-16-2016 )Texasdude74 Wrote: [ -> ]I think the biggest advantage in favor of Cummins is insite. Being able to monitor what's going on with your truck and make changes as you see fit. Look at the MX-13 for example. Their software costs over $4k and just allows you to read and clear codes, you can't change much of anything and it certainly won't walk you through fixing things. The Volvo engines are no better, not user friendly at all. Even the almighty Cat engines have just multi thousand dollar scan tools. Insite is unique.I would add cummins quickserve resource is the great plus compare to any others brands.
(11-16-2016 )389driver Wrote: [ -> ](11-16-2016 )Texasdude74 Wrote: [ -> ]I think the biggest advantage in favor of Cummins is insite. Being able to monitor what's going on with your truck and make changes as you see fit. Look at the MX-13 for example. Their software costs over $4k and just allows you to read and clear codes, you can't change much of anything and it certainly won't walk you through fixing things. The Volvo engines are no better, not user friendly at all. Even the almighty Cat engines have just multi thousand dollar scan tools. Insite is unique.
Ever heard of CAT Electronic Technician? Just as powerful as INSITE and can be obtained through similar channels.
